UCA. 21mm bolt stuck to bushing.
EnvoySLE02
7
Hello,
So I am replacing the UCAs on my truck due to play/noise from the bushings. I started on the Passenger side, and ran into a problem immediately. The rearward facing bolt is stuck to the bushing. The bushing spins with the bolt, and so the UCA end over there moves back when I spin the bolt, not just the bolt head. I have not tried heat on that end yet - it was getting late and I had more work to do on the truck so I got that out of the way. Anybody run into this before? By the way, I can not find the 21mm bolt listed anywhere online.
We usually recommend LOTS of PB Blaster starting a few days before any work like this in salt-using states.
Special GM-only bolts like this may be available from the dealer, or on-line GM-only discount vendors like parts4chevys.com
Boricua SS
3,080
Ohio
:iagree:
I just lowered mine and replaced the UCA.. for a week, I let my truck sit with PB Blaster on it, and spraying more on everyday... when the weekend came, I was able to get the bolt out with just a basic 21mm wrench and a home made leverage bar...
EnvoySLE02
7
I sprayed them with pb a week or so ago. The first bolt came off easily, the bushing spun on the second. I don't think I can cut the control arm and bushing off without damaging the bolt, so ill try the torch next.
ylab
19
On the UCA the 'Nut' is tack-welded to the housing, if it's spinning, the tack-weld may have broken when you attempted to break free. It's happened to a couple of members in the past. Just a head up, watch the removal or initial force used to free those UCA mounting bolts.
filthycasual
