Transmission Fluid Quantity
BrianF
1,193
West central Sask.
I don't see any issue with clearing out the cooler but in all reality the exchange method does not net you 100% clean fluid. Do not sweat half a litre here and there. In the grand scheme of things it does not make a difference.
As well, I am not sure how the cooler line returns to the transmission. You could always just disconnect both input and output lines and clear it out.
Dec 5, 2011
577
Central Pennsylvania
Is the lack of 100% change due to the TC or just other residual fluid? I was considering using one of those "flush" products that claims to remove varnish and such but would want to get as much of the old fluid and flush product out as possible. Are they worth it is it more snake oil than anything?
Mektek
656
FL
I recommend Valvoline max life Dex6 at Autozone for around $28 for a gallon. Sometimes it goies on sale for less... On the bottle it even claims to be synthetic.
I had a car that started to shift hard into every gear. I flushed the transmission with this and after about 100 miles the shifting returned to normal and was ok for three years until I sold the car.
Reactions: TequilaWarrior
BrianF
1,193
West central Sask.
I doubt a flush product will make any difference. I have never seen any sort of varnish in any of the transmissions I have ripped apart over the years. The worst is the usual clutch debris in the pan. ATF is not subject to blowby, moisture, acids or soot. Unless you are trying to limp along a dying transmission, I would not recommend any additives. Mind you I am not a professional mechanic, nor do I play one on tv.
If you are getting some TC shudder I would suggest a quality group 3 or 4 based ATF, like Maxlife, Amsoil (I think they have a great product with a ridiculous price) or similar. I ran a group 4 in my Ram 1500 with the 545RFE. Its a product made in Saskatchewan, Co-op ATF SL, multivehicle 7cSt fluid. 9$ a liter and it did a great job in that trans under some heavy towing. Its also doing just fine in my AT2 transfer case and various PS systems.
I am not sure how much fluid is left in the system for sure or how much the TC retains, if any. When I did my TB in 2014, I used about 13 or so liters and the fluid was bright pink pumping out. Dipstick checks to this day still show it bright pink and smelling as good as ATF should be. The 4L60e in my 1993 K1500 used maybe 11-12 liters if I recall to flush out the nasty dark brown ATF. Dipstick check shows it nice and pink still.
Don't over think this, just pump out the old and pour in some new stuff.
nadmak
