3 local mechanics were "stumped" when I took my 2004 Envoy in to be looked at. It started to feel like it was not getting enough power occasionally when I was driving between 55 -65 mph, the RMP's would slightly fluctuate, and sometimes it started to shake when it was struggling. One shop replaced a O2 sensor and spark plugs and also replaced a starter that was bad, the other shop drained and refilled my trans. fluid. Both places said that should take care of the problem, and there were no codes coming up a scan, but its still doing the same thing. My trans. fluid now smells burnt and is dark. I thought it was/is a trans issue but one of the shops thinks its a misfire issue and I need a air pump replaced. Does that sound right to you all? Ive had it for 6 years and have never replaced or had to repair the transmission... Trucks got 175,000 miles on it & Im wondering if I should put more $$ into fixing it.
One more question- after left the shop that replaced the spark plugs and O2 sensor my low beam headlights no longer worked. The high beams work and I have daytime running lights but no low beam lights. Any idea why or how I can try to fix that myself?
Thanks y'all
Thanks y'all
