For the last few years after I use 4wd more often then not the next time I start the truck and the TCCM wakes it thinks it is neutral and will blink until I put the trans. in neutral so it can "switch" to 2 hi.
I tried put it actually in neutral and it switches and tells me it has but it does not fully go into it.
its makes a terrible noise if you do what the manual says to do and do it with the engine running and test with drive and reverse (so I do not do that). Some times it will roll in park sometimes it does not. The other other 4 ranges work fine. The fluid has 30-40K on it.
Ideas?
Ideas?
