TPMS confusion
wormwood1978
75
2008 Trailblazer. Several months ago, my TPMS light came on despite my tire pressure being good. Its starts by blinking and then goes solid. I have reset the error codes and they come back a day a later. My autel scanner appears to show that all the sensors are relaying data but I'm still getting error codes on all the sensors.
I had Walmart install new aftermarket TPMS sensors in 2017.
Should I try to do a relearn? I don't think all the sensors are now bad but I'm open to that possibility. What do you think is going on?
One or more of The sensors could be going bad. Unless you have a DIC or a scanner capable of showing each sensor, there is no way to know which one.
A flashing light without a chime that goes solid after a while means a system or sensor issue. A light with a chime means a low tire.
wormwood1978
75
My scanner appears to show problems with all four sensors. Considering they were replaced with aftermarket sensors in 2017 do you think the most likely explanation is that all four sensors went bad as opposed to another explanation?
My scanner is communicating via the odb II port and is not RF communicating with the sensors directly.
TJBaker57
2,902
Colorado
When I scan my 05 Yukon there is a value for battery level of each sensor. Do you see this when you scan yours? I have one sensor that has reported low battery for a few years now.
wormwood1978
75
My ODB scanner does not do that. I'm thinking about purchasing a $110 TPMS scanner that will though.
TJBaker57
2,902
Colorado
Well even the Tech2 doesn't actually read out battery directly. But it does list a "low battery mode" as opposed to "stationary" or whatever...
This one sensor of mine is too low to properly complete a relearn so I have resorted to writing the sensor positions directly to memory myself instead of wasting time trying to get the relearn to work.
chriswilson5585
