I have a 2002 trailblazer that hesitates for one second only when you leave a stop light. It is less noticeable when a/c pump is running.
If you accelerate very slowly it does not hesitate, if you punch it it does not hesitate.
It does not hesitate while engine is cold and idle air control valve is open.
It will only hesitate off a dead idle
when you leave a stop light and accelerate, the enigne rpm's drop the engine shutters and stumbles, then it seems like the pcm catches itself and the truck takes right off. idles and runs great otherwise.
I have a check engine light on code p1345 for cam/crank correlation which I could care less about, i just need to fix the stumble
Here is what I have replaced so far, I have serviced my own vehicles all my life but this one im baffled at
fresh gas, oil, ac delco irdium plugs
2 different throttle bodies, both clean
cam positon sensor
crank position sensor
cam vvt selsnoid
gas pedal
could a bad fuel pressure regulator, fuel filter, or failing fuel pump cause this?
cam positon sensor
cam vvt selsnoid
gas pedal
