Tinted Headlights
10,686
:eek: If there was any kind of oil/grease on the lens when you sprayed them, that's gonna be a problem down the road. Start the clock until you start to see some peeling. :hissyfit: This will be a good lesson for other members in the future. :yes:
YOUNG
itll be alright, ill probably end up changing it up again this summer. Might get some new lights. crack them open paint the insides and install a few things.
how long you think before i start see peeling come on lets hear those bets!
10,686
Way too many factors play in. Weather, temperatures, frequency/duration of your drives, road debris (bug guts/rock chips), and whether or not there was any type of oils/chemicals/wax on the headlights to begin with. Just have to wait and see what happens.
YOUNG
i guess thats what we will do. wait and see..
fishguy1123
310
So, how "should" you clean them" Head lights, tails, mirror turn etc...? It soap and water doesn't work, what does?
4wVoy
254
i use soap and water then hit it with isopropyl alcohol, that should take off whatever the soap and water doesnt get
ItsOnVoy
2,401
Sanding with a 2000grit sand paper makes a big difference!!! Does not seem like much but makes the head light much smoother and helps hold the paint pretty good!! And then your clear will protect the light from there! But if you want, but a set of halo projectors (I know you don't like halos) so open those up, disable the halos and Mr Smith mod them and paint the inside! Would look sick IMO :yes:
YOUNG
I like the look of some halos. but the projectors have to be bright enough and i really dont have much experience with projectors.
(wear i live u need alot of light because of lack of street lights, and curvy roads.)
ItsOnVoy
2,401
the projectors will be MUCH better then what we have!! They will even out those HID's instead of seeing hot spots! Puts those HID's to good use lol Plus you have those high beams for the spots you cannot see :thumbsup:
ItsOnVoy
2,401
YOUNG said:
Highbeams stay on out here, the most dangerest thing out here is when someone forgets to turn them off and your coming around a curve and can see S*** :hissyfit:
Yeah I have had to deal with people like that also!! That is why I show them my quad beams :biggrin::Boxin:
YOUNG
so we all know that my tinted headlights are super dark!
but here is some pictures of the blinkers as night. camera phones dont do lights justice, but it shows up well enough.
go ahead lets here your opinions! :thumbsup:
10,686
Looks good man, maybe some side shots for the corner lights?
ItsOnVoy
2,401
:iagree:
night shots are one thing, lets see some day time shots of the blinkers :raspberry::wink: lol
Voymom
2,523
ItsOnVoy said:
: lets see some day time shots of the blinkers :raspberry::wink: lol
You probably won't see much lol I did VHT on my outside mirror signals...can't even tell they are signals during the day :redface: Oh and mine only have 3 coats of niteshade....
I'm to much of a :lipsrsealed: to do my head lights or tails. I would rather have someone else mess them up for me lol And switchbacks are badass. I plan on possibly doing them in my truck...one day.
But they do look good, so good Job!!
YOUNG
ItsOnVoy said:
:iagree:
ummm people were asking for night shots so i posted those, and day shots ehhhh well lets just say my state doesnt require blinkers to be used! ha. :lipsrsealed: i know, not as safe. but ill be upgrading the light by time summer comes as i dont drive alot now.
Voymom
2,523
SOON
Like when you decide to take a road trip here to Iowa and do them for me soon? :biggrin:
10,686
Voymom said:
SOON
:raspberry: Let me respond to that with a question, "How many hubby's does it take to replace a turn signal light bulb?" :rotfl:
Young, are those stock turn signal bulbs? :undecided:
If they are, I bet you know what I'm gonna say next!! :yes:
Voymom
2,523
It's not switching the lights that I'm worried about...it's the wiring. I seen pictures of your LED's being soldered in the cluster panel and have to take a xanax from the anxiety I get lol I just know if I try doing something like that I'm going to screw it all up. Hell I damn near had a heart attack niteshading my mirror signals :rotfl:
ItsOnVoy
2,401
YOUNG run away before Carlton makes you end up.....
Then you spend your last dollar on this
:dielaugh::raspberry::tongue:
:rotfl::rotfl: One for each LED on the switchback? haha
10,686
Well, you can relax a lil bit, since the switchbacks are actual bulbs, that pop right into your existing sockets. Only wiring (possibly) would be adding load resistors. A plug and play alternative to that, is replacing the flasher module which is just above and to the left of the brake pedal, with an LED flasher module. I went with the module swap, took about 5 minutes. Hardest part was contorting the right way to be able to look upwards under the dash from the floor. For someone vertically challenged, it might be a lil easier :wink:
We'll talk about cluster and other interior device modding later :yes:
:crackup: Hey now, I know I'm not the only one who's been feeding LED mod bugs around here!
YOUNG
so if i add switbacks i will forsure need a flasher module? as im not into messing with the wiring too much.
10,686
In your case, yep. Part# LM487 $34 from RockAuto.
getimage.php
ItsOnVoy
2,401
YOUNG said:
seems plug and play everything, and i like plug and play! makes it about to easy.
looks like ill be looking at ordering switchbacks Later tonight
Good to hear that...let me help you out :biggrin:
[EBAY]330695585747[/EBAY]
:rotfl::raspberry:
ItsOnVoy
2,401
:poke: :confused: And you try to talk about me Sam? :hopeless: :raspberry:
:rotfl: Hey you did all the feeding!! You made the cake..now I might as well add the frosting to finish it :biggrin: (and I know we all love our frosting) lol
Might as well help him if he is already convinced loll
YOUNG
i hope your buying them for me! :raspberry:
i currently have to save any money i can for my senior trip to Germany this year, so i cant do any mods that cost any $$$ really.
jpleasant
26
Okay I jumped out and tinted my headlights now I need help. The tint I used was VHT and it made the head and fog light plastic look like they were cracking. Like glass does right before it breaks. I am confused at why this happened. I had the tail-lights done with the same product and the same way and they didn't turn out like that. Does anybody have any suggestions on how I could do it to make it look better. By-the-Way- I water sanded them then sprayed them with coats, then glosses them with coats, water sanded again lightly, and then waxed them.
jrSS
U wet sanded them b4 u applied vht?? U don't want them smooth when u apply any paint. U want a little texture so that the paint can "grip". Then after u apply one coat u can sand.
ItsOnVoy
2,401
yeah sand between each coat with like 2000 grit sand paper, wet sand them. What I had done with mine and there just fine
jpleasant
26
I will have to post pictures tomorrow when it is daylight. I need direct instructions on how to tint the headlights, foglights, and tail-lights to make them look smoked. I guess I took it a little far with the tint. IT IS DARK!!! the HID's don't even put out good light. So what I am asking is can someone give me removal directions and reapplying directions. My tail-lights are perfect just a little to dark, but they didn't crack. I thank you all in advance for your help.
1.Is VHT spray tint OK to smoke them with?
2.How do I keep them from cracking?
3.How do I fix the already cracked look of the headlight and foglights for the next time?
4.Do I need to be in an warm environment
5.How do I remove them without causing more damage
jrSS
Of course u need a warm environment or else paint won't cure. If they r too dark sand down and start over. Vht is a good product.
jpleasant
26
I Prob will remove it all and do more of a smoke finish and just gloss the :lipsrsealed: out of it. I would still like some input on how others have done theirs and how they have turned out.
keithdm
