Tie Rod End Fastener Info
stormsurge
386
I couldn't find this any ware. The nuts on the tie rods are 21mm on the end. The two that are together are 22mm and 26mm. The moogs had a 24mm. I picked up the whole set just to change the ends. Always good to have around I guess.
Reactions: The_Roadie
IllogicTC
3,452
I had the shop do mine since I was in for inspection, but this is good info to have. Some people don't have a fleshed-out toolset yet and these nuts are all a bit larger than the common set the beginning DIY-er would likely pick up. Definitely a good reason to get a full-featured set; either as a whole or piece by piece (Sears sells Craftsman, Lowe's Kobalt, and Home Depot's Husky all sell individual wrenches for example). If the cost can't be justified, a couple of knuckle-buster (crescent wrenches) that have a nice-sized jaw can do in a pinch, though not as handily.
Reactions: stormsurge
stormsurge
386
Sears has a full set up to 30mm for around $80.00. You have to order it online though.
ahmed1999
