- May 24, 2013
- 54
So I have a squeak in the front end of my truck while turning and going over a bump. Last weekend, I replaced the stabilizer bar bushings and end links. Looking around with the tire off, I decided that I should replace my ball joints at some point since the boots were cracked. When I started driving it on Monday, the squeak was still there. (Before anyone asks, I did monkey with the hood bumpers and it was not them.) Given the chance to spend three days on the forums, I decided that I would shoot this squirrel with a 12ga at a distance of two feet.
So here's what I have showing up this week so far:
Lower Control Arms
Lower Ball Joints
Upper Control Arms
Upper Ball Joints
Quick Struts
Hub Assemblies
Brake Shields
Since I'm saving a bunch of labor money, I decided to buy some stuff that I will probably never use again, but who doesn't want more tools?:
35mm Impact Socket
Pickle Fork Set
Air Hammer
Ball Joint Press Kit
Already in the garage:
Torque Wrenches
Pitman Puller
Impact Sockets
Air Wrench
Air Ratchet
Big Hammers
Big Pipe
The questions are:
Should I be replacing anything else while I have the whole dang thing torn apart?
Should I buy more tools?
(BTW: If you find this post on the OS, ignore it. I was flipping back and forth during my reserch and posted on the wrong one. )
Lower Control Arms
Lower Ball Joints
Upper Control Arms
Upper Ball Joints
Quick Struts
Hub Assemblies
Brake Shields
35mm Impact Socket
Pickle Fork Set
Air Hammer
Torque Wrenches
Pitman Puller
Impact Sockets
Air Wrench
Air Ratchet
Big Hammers
Big Pipe
The questions are:
