I went to go to the store and started my truck, as it has been doing every once in awhile it would tick (the tick you get when you try to start but the battery is dead) then it started, I let it warm up then went to the store and shut it off. Came out and went to start it and nothing not even a tic. So I went under the hood and jiggled the wires just to check and my dash lights were on but still no start, no power windows or locks and no chime letting me know my key was in the ignition and as we all know if the battery is dead our trucks will not release the keys.
So I walked home and went back down with my son to jump it and while the lights on the dash were no longer dim (the lights for the gears and mileage) still the same no windows or locks no chime and nothing from the starter so I’m assuming it’s a fuse, relay or the ignition?? So which of the For mentioned fuse/relay do all of these have in common because being it’s 10 degrees out I have no desire to walk there and go threw them one by one. Thanks you very much!
