NEED HELP Sunroof Front Drain Tube
MikeHayes
72
Vermont
i have a 2004 Trailblazer EXT LT with the factory sunroof, The driver side drain tube has come off and water runs down the piller. Does anyone know how to get to it so I can reattach it?
Thanks in Advance
littleblazer
9,266
Do you know where it came off? I believe the headliner is just clipped in place. If it's at the door I think there is limited access under the dash. I'm not 100 percent sure though.
10,688
If you have a round plastic cap near the top of your A pillar like my EXT does, there's a screw under there. So you'd have to remove that. The rest of the pillar is held on by clips, so just pull.
You might be able to pull the corner of the headliner down enough to squeeze your hand in there. Is it leaking in the headliner, or just down by the floor?
Reactions: Trkdrvremt
MikeHayes
72
Vermont
It's leaking where the A pillar connects to the main part of the dash and runs down the side of it to the floor.
Trkdrvremt
351
NJ
I had a blocked one on the pass side.. All I had to do was pull the a piller and the center console/lights. Easy to get to from there...
fhenninger
