SOLVED! Sudden loss of 3rd/4th gear
zippy411
21
20814
2003 Suburban LT 5.3L 4x4 210xxx miles
No check engine codes
Transmission is a 3KCD
No previous issues with transmission. Never noticed any slipping gears previously. Complete fluid change out done personally ~70k miles ago with GM fluid. Fluid still looks and smells good. Gauge cluster has transmission temp gauge and It has never overheated that I've noticed. Usually never over 150, went up to 210 a couple times when towing/country driving.
I drove ~90 minutes mostly highway with no issues doing 70mph. I arrived at a location and idled for ~30 minutes and when I was leaving the location the transmission would no longer shift higher than second gear. In drive first and second gear work fine but when it feels like it is attempting to shift into third gear it feels like neutral, the engine revs high but speed does not increase. Manually shifting into first or second works fine as well but manually shifting into third results in the same neutral feel with free revving engine and no forward power. I was able to drive off highway home in second gear keeping the rpms from getting too high.
I sourced and swapped out another 3KCD from a 2003 Tahoe that was being parted out supposedly from rusted out brake lines. I swapped this transmission with mine successfully but the same free revving neutral third gear still exists. I am not sure about the likelihood of getting another transmission with my same exact issue so I'm beginning to wonder if the issue is electrical outside of the transmission. I tested all the fuses in the engine fuse block and driver's door fuse block and didn't find any blown fuses. The replacement transmission came with the transfer case as well which I left attached when I swapped it, if that makes any difference. I dropped the pan, replaced the filter, and topped off the fluid with Valvoline Maxlife as well before testing the replacement. The new transfer case got Auto-trak II.
I will be borrowing a bidirectional scanner to see if I can read live transmission data to make sure it is actually calling for third and test the solenoids.
I read that limp mode for the transmission with force it to be third gear in "drive" and "third". How would I force it to go into limp mode?
What guidance can anyone here give me on diagnostic avenues to explore?
I am looking at possibly rebuilding the original transmission myself as well.
zippy411
21
20814
Testing with a bidirectional scanner shows the transmission calling for third but never achieving a shift. It says it is able to grab fourth but the rpms are more like it is falling back into second gear. Cycling the solenoids with the scanner provides an audible click from 1-2 solenoid, 2-3 solenoid, 3-2 downshift solenoid, and TCC control solenoid.
Sure sounds like she's done but still strange that both exhibited the same problem. Could just be that both had 3rd gear clutches failed. Not unheard of on these with significant mileage.
Reprise
2,724
Coming in late here, but Moose speaks truth, as always. From the described symptoms, your 3rd clutch has given up the ghost.
The 3rd clutch is one of the weak areas of the 4L60, and it can't be fully bulletproofed (design limitation), although HD clutches are available for it and will help (Raybestos 'High Energy' and Alto 'red' frictions are the preferred solutions for most people / daily drivers). My Envoy got the High Energy when it was rebuilt a few years back; 1-2 is a little firmer when cold, but I'd rather that than the
At 210K (and who knows on the replacement), you can expect the 3rd clutch to wear out, especially in the later versions (2004-onward were the worst; GM figured out where they could save $ in material costs over the lifespan of this transmission, and the earlier ones were a bit more robust than the later ones). They're pretty good units, especially compared to their competition at the time, but the 3rd clutch and a couple of other things make them less durable than the big brother 4L80, especially when used in a HD capacity (plowing, towing heavy, etc.)
BTW, 'limp mode' is a failsafe for electronic issues -- 3rd is the only gear in the 4L60E that doesn't require electronic activation, so it became the 'limp home' gear. The 3rd clutch breaking is a physical problem, so when it goes, the trans will flare above about 25-28 mph, as it can't shift to 3rd at that point, automatically or manually. So limp mode isn't going to help you, here.
zippy411
21
20814
Thanks for the replies. I guess I will be trying my hand at rebuilding a 4l60e. I'll let you know how it goes. I've got the original one mostly apart now, I just need to make the special tool for removing the spring cages.
zippy411
21
20814
3/4 clutch pack pictures attached
zippy411
21
20814
I have to take a break while a new set of 3/4 clutch boost clip springs get delivered. The rebuild kit I got did not include them. These don't seem to have maintained the springiness(technical term) that it is supposed to have. I wonder if the lack of spring contributed to the clutch pack failure or is a result of the extreme heat from the clutch pack failure.
Here are pictures comparing mine to a new one.
zippy411
21
20814
I am using these videos to assist with this project.
Removal
Teardown
Reassembly
Install
zippy411
21
20814
I've ordered and been using these parts.
Rebuild kit
Torx plus 50 bit (for bell housing bolts, zipped right out with big impact)
Valve body spacer plate (mine has damaged check ball holes)
Transmission fluid cooler line fittings x2
Sunshell
Pressure control solenoid
Torque converter clutch PWM Valve
3-2 shift solenoid
Shift solenoid valve x2
Manual valve position pressure switch
3/4 clutch boost spring x5
Transmission assembly lube
And bonus, the rear main seal I replaced when I switched transmissions the first time.
zippy411
21
20814
And here are the special tools from the videos that I made for compressing the spring cages. They have worked great. The black metal one was made from an old lawn mower blade I had.
I have a set of harbor freight snap ring pliers. They really weren't working due to the rounded tips. I filed the outside edges of the tips of a couple of them flat which helped tremendously with snap ring removals and installs.
zippy411
21
20814
Well it looks like I'll have to take another pause in the rebuild. I didn't realize the kit did not include a new pump boost valve so I will wait for a replacement to arrive. Based on the Sonnax chart and my measurements it looks like I would need a 77898E-4K boost valve. I measured valve length at 1.905 and EPC Spool diameter at 0.470.
zippy411
21
20814
I did run into an issue when rebuilding the 3/4 clutch pack. The original clutch pack contained 5 steels and 6 frictions. The replacement pack had 6 steels and 6 frictions. In the video the guy also had an extra steel that he just set aside and still got a good clearance measurement of 0.060" at the end with feeler gauges. When I set the extra one aside I ended up with a gap of way over the upper limit of .085". when adding the extra steel to the bottom of the stack the clearance is right at 0.085". the thickness of the original 5 plates was 0.1045". the thickness of the new plates are 0.0785". I cannot just reuse all the old plates due due to significant scoring being present on two of them.
The replacement pack of steels did not have a branding/label on them which now seems concerning. The replacement kit of clutches was Exedy EFK173 which has 3/4 clutches that are 0.080" thick, which I believe is the original thickness.
What would the recommended solution be?
Should I just order a different/better 3/4 clutch pack?
Edit: I ordered original thickness plates from this website. That should resolve my issue. It seems like the 0.078" plates were the medium thickness plate option for the 3/4 clutch pack and 0.060" would be the thin plate option.
7,750
This is an interesting "Side By Side" Comparison showing the differences between the GM Factory OEM Boost Valve and the Sonnax Kit Conversion:
And here is Pro Transmission Builder opining (Via Dual Camera Split Screens) on "The Aging 4L60E Transmissions" and the problem of them having a HUGE Trans-Fluid NEED to be present for the 3-4 Clutch activities:
Reactions: zippy411
zippy411
21
20814
That is a great video that touches on several points that I don't recall seeing in the other videos I linked. Thanks for sharing! I'll definitely be checking a few things he mentioned before I put it back together.
I'll be checking for the 3/4 system leaks he mentioned.
I do have a precision straight edge from when I replaced the cylinder heads on my 4runner. I'll use that to check the drum and valve body surfaces.
zippy411
21
20814
GM pump boost valve (right with double rib piston) vs Sonnax 77898E-4K (left with single channel piston and two slots for o-rings)
The Sonnax boost valve has a smaller single upper hole compared to a slightly larger single hole on the GM. The Sonnax also only has a single slightly smaller lower hole whereas the GM has two slightly larger lower holes, one on each side. The Sonnax also has the two slots for the o-rings vs no o-rings on the GM. The fit on the Sonnax was definitely a little more snug than the GM. It still returned up smoothly with spring pressure after being pushed down then released.
zippy411
21
20814
I did not realize that the Sonnax 74480D, 3rd accumulator check ball with seat pill, was just a packed GM part 8634400.
I also ordered the Sonnax 77701-076, check valve kit servo release, that is a backup for the 3rd accumulator check ball.
zippy411
21
20814
I had nicked a seal on the reverse input drum piston trying to seat it with feeler gauges so I ordered a replacement set that came with a "lip wizard". I practiced a couple time on the nicked seal to make sure I had the technique down. It made it easy to get the drum seated with the new seals.
zippy411
21
20814
I tested the 3rd accumulator check ball and it wasn't leaking into the case but I figured it was a cheap part with over 200k on it so I replaced it anyway and added the Sonnax servo check valve kit on top of it just below flush. It fit snugly without the o-ring so per the Sonnax instructions I left the o-ring out. It tested without leaks on the interior as well after install. This special tool worked perfectly for removing the old pill and then I used a 3/8" punch that was perfect size to tap the new pill into position. My 10lb slide hammer threads were way too big for this special tool but the Harbor freight 2lb slide hammer kit was the right size thread and got the pill removed easily.
Also the valve body mating surfaces were nice and flat when checked. With my precision straight edge.
Teckpak T700307 Capsule Driver
3/8" - 16 threads
zippy411
21
20814
The new 0.106" 3/4 clutch steels arrived and I rebuilt the clutch pack with them. The new clearance is measuring 0.030". While not necessarily manufacturer spec that is pretty much perfect from what I'm understanding. If you think that is too tight I could switch one of the 0.106" steels with a 0.078" steel.
Testing with an air compressor showed good function of all clutch packs and pistons holding pressure.
zippy411
21
20814
I ordered a new Sonnax 3-2 control valve spring. You can tell from the picture how compressed the old spring had gotten.
Sonnax 77754-23 4L60E 3-2 Control Valve Spring
The kit I ordered had a new seal for the forward accumulator piston but it is a plastic piston. I really didn't want to put a 20 year old piece of plastic back in the transmission because I read these can be prone to cracking so I ordered the Sonnax aluminum replacement.
Sonnax 74927-AP Forward Accumulator Piston Aluminum
I used this kit to replace the 1-2 and 3-4 accumulator pistons.
ACDelco GM Original Equipment 24221919 Automatic Transmission 1-2 and 3-4 Accumulator Piston Kit with Pistons
The cooler line fittings I had ordered were apparently the wrong ones. Their threads were much larger. Reading into it revealed that the ones I ordered are actually for the radiator side connections. So I ordered the Dorman replacements that fit. They are installed without issue. In the picture the old one is on the left, the correct Dorman one is in the middle, and the wrong GM one is on the right.
Dorman 800-604 Transmission Line Connector With 3/8 Tube X 1/4-18 In. Thread​
zippy411
21
20814
I replaced the Teflon seals as well. These are the ones that arrived in the kit.
I installed them using these resizer tools. The kit worked great. I would recommend not using the extensions that go into the expanders and just use the expansion tips by themselves. When attempting the first time I had the new seals get caught up on the lip between the two pieces so I just took out the extensions and just passed over the wide part slower to allow more expansion time. Then CAREFULLY working the compression sizers on worked perfectly to size the rings back down. I kept the sizers on for about half an hour and took them off right before reassembly.
I reassembled the valve body with new gasket plate and all new solenoids. The transmission is now completely reassembled and I should be swapping them out later this week.
7,750
For Post-Installation Diagnostic & Testing Activities:
  • 4L60E_80E_CODE_BOOK.pdf
zippy411
21
20814
I completed swapping in my now rebuilt original transmission and it only took seven hours, half the time of my first swap!
More importantly, I have third and fourth gear back! The transmission shifts so smooth. Thank you for all your help!
If any issues do pop up over the long term I'll post an update.
zippy411
21
20814
I noticed while driving that the transmission fluid got up to temperature a lot faster that it used to. Not overheating, but just got up to 150 faster. My initial thought was that I was too aggressive packing the 3/4 clutch pack to 0.030" and it was creating friction when it shouldn't.
So to test that I drove on the highway to keep that clutch pack locked up which would eliminate that as a source of extra friction/heat.The transmission temp never rose above 150. I then drove a few miles back home manually in second gear and the temps crept up to about 180. This seemed to confirm my theory.
So last night I pulled the transmission. Took it partially apart, replaced one of the 0.106" 3/4 clutch plates with a 0.078" plate. The clutch pack clearance was 0.060" after. I then reassembled and reinstalled the transmission.
I just repeated my same driving test. First thing I noticed is that transmission temp was still at 100 where it had been already at 150 previously. The transmission got up to temp of 150 during the test but didn't rise above, even during the second gear portion.
I'm going to mark that issue as resolved. Hopefully that was my only mistake. The transmission still works great and I caught it so early that the 3/4 clutch pack was still in perfect shape.
On the plus side I've gotten really good at removing and rebuilding this transmission. It isn't intimidating at all anymore. I just wish I had a lift. I'm getting tired of laying on my back on the garage floor.
chriswilson5585
