02 Bravada, original head unit, original speakers, I get a low buzz only on the front passenger speaker which happens as soon as the accessory is turned on. The buzzing isn't affected by whether the engine is running or not or the volume setting of the speakers. When I play music, the buzzing doesn't go away but otherwise the sound is fine
When the door panel was removed, the wires and connectors looked fine. Could it be a loose ground, not from the head unit but maybe at the amplifier side?
Images from ebay for my headunit, if it helps
