rpm/voltmeter problem
mrm143
42
Mark20 said:
How old is the battery? Had my voltmeter going crazy like yours and it was the battery retiring. I don't remember the engine RPM changing that much though.
Not sure just bought truck will have batt checked while at store too lol.... im just hoping the rpm drop is tied int o one of these.... should I even bother with plugs just yet as I don't see that as being related but I could be wrong
MAY03LT
Delmarva
mrm143, your threads were merged so that all posts related to your problem are in the same place.
mrm143
42
mrm143 said:
Alt and batt check good doing plugs now
Old plugs
So far so good rpm is steady and running better and the wrong plugs were installed
STLtrailbSS
Sorry for getting back so late! :no: Glad you got it fixed! Want to come change some spark plugs for me now?:yes:
mrm143
42
And now we pop a p0410 code lol
I already found an article so no worries their and wondering if that would be what the cold start fluctuation is as it is still doing that... The other issue has been solved
Can't find any pics as to where the pump and relay are but I do know where the check valve is...
mrm143
42
I think I figured it out if this makes sense...
Car turns on cold start... the sai turbine is supposed to run for approx 20 secs approx the same amount of time my volt guage goes nutty...
So..... their has to be an issue with the turbine under the car..creating some type of voltage draw. so that's my next step is to test the fan and backtrack from their...
Relay is next to the pump #6. Sorry I don't have a close up picture of the relay on my truck.
STLtrailbSS
mrm143 said:
I wouldn't mind wasn't bad at all
LOL last off topic post.. on the SS you have to remove the passenger tire to get the farthest plug its a pain
woody79
351
Hope this helps a little. I did create a thread on the OS regarding this. Here are some pics from it....
This is the pump and relay. Located on the frame rail under the drivers side behind the wheel well.
This is the location of the valve
Once I had replace the valve I took the old one apart and found out why it wasn't opening.
mrm143
42
View attachment 4657View attachment 4658
Thanks I did search and when it took me to the os most of the pics were deleted
woody79
351
No worries. I think you'll find thats because 90% of the people who posted those pics moved over here :biggrin:
mrm143
42
I understand LOL
So hoping my logic is correct, but truck was to warm this morning after wife took kids to school to test fan... I own a pawn shop and have one of those auto meters here, i guess it's to test relays?? Not sure how it works, but couldnt I hook the fan up to that and it is supposed to supply 12 volts or something?
Just forget I had it LOL, someone pawned it and never came back, it is a "power probe"
woody79
351
mrm143 said:
I understand LOL
lol that figures ... You can remove the SAIS Turbine and put it on a work bench and hook 12v to it to test it. Never done it myself. The Turbine is held to the frame with 3 bolts I believe (not to sure of the size). This will tell you if the turbine is in working order. Your can also just pull the hoses off the turbine and see if any water comes outs as this seems to be a common issue.
Fishermandude
