I need to find a replacement catalytic converter for my 03 ext. tb. I was having some overheating issues which lead back to a hole in the coolant loop (sucking air) after that problem was fixed I could not get the engine to rev over 1500 rpms. this lead to removing the o2 sensor for testing and I can now get up to speed without bogging down, so i am certain the cat is plugged. Im looking for a bolt on catalytic converter as I cant do the welding atm. is there a bolt on converter that people have had good success with? I am located in florida and we don't have any emissions to deal with. also so i dont prematurely wear out the new one should i be replacing/ testing anything else besides the t-stat?
