I wanted to post some pictures from this afternoon when I pulled the engine and transmission out of a 2004 envoy. It’s a 2 Wheel Dr. so that made it easier.
i’ve spent a lot of time on her reading about pulling the engine and transmission. If you people claim they pulled both at the same time but couldn’t find any details. It seemed like a better idea to pull them both together. Instead of wrestling around with the transmission under the vehicle then supporting it when taking the engine out.
I thought everything went very smoothly. I believe I got lucky when I put the straps on that they were the right link so that the engine was at the right angle to come up and out of the engine bay. I felt like I was stripping the nut when removing a torque converter bolts so that was another reason to loosen the torque converter bolts through the starter hole once the engine and transmission were out.
I was lucky that no bolts or other parts broke during removal.I was lucky that no bolts or other parts broke during removal. Normally I dread anything related to the exhaust but all of the fasteners came out with no problem.
So I wanted to post about my experience and if you have any questions and let me know. I appreciate all of the information that is on this forum so this will help repay those that helped me
The background for why I removed the engine is several reasons. The vehicle does not have a title so I saw no future in it therefore I’m pulling in as many usable parts off of it as I can. The engine seem to run well although it does have serious sludge. Compression was very good with all cylinders around 180. So I wanted to use it in a 2005 envoy which has cylinder head issues... broken exhaust valve spring and intake Manifold bolts broken in the head. Removing ahead and likely dealing with broken cylinder head bolts didn’t seem worth it. Replacing the engine would be easier.
