Hi all, on my 07 V8 Rainier, all at once the rear wiper & washer, the Key Fob and the TPMS stopped working. I've tried both fobs and new batteries, The TPMS screen on the dash showing the tire pressures is just a black screen. I've checked all of the fuses in both blocks for continuity and can't see a cracked wire when pulling the boot down covering the wires in the tail gate. I disconnected the battery and let it sit. Prior to disconnecting the battery the tpms screen showed the LF, RF, RR, RF tires but no pressures and there was a tpms warning light and message saying it was malfunctioning and after I reconnected the battery, the tpms screen is blank and the warning light and message are gone. Not sure what to try next. Have had the car since since 09 so hasn't had anything crazy happen to it.
Thank you
Thank you
