Rear Spring Rates/RPO's?
Playsinsnow
9,727
After killing some time reading threads on suspensions, I was wondering if rear and front spring rates are identical for a model?
I have the 84s up front with the pink tag, but the rear tag is purple/lavender and reads "15207741" and "YNT". The rear squats more than I like when loading the back up with only a few hundred pounds, tops, and it has become worse over the years.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
Playsinsnow
9,727
Thanks for the links Thumper :thumbsup:
Guess my question now is are the rear spring tag colors identical to the fronts regarding spring rates? Meaning is the rear lavender tag spring rate equivalent to a lavender tag front spring?I'd assume so...
fhenninger
