- Apr 9, 2012
- 934
So for the last 2 weeks, I've been getting a popping/clanking sound coming from the rear. Doesn't matter if the road is smooth, bumpy or has a few cracks and whatnot. Thought it was my rear sway bar links. Both sides are solid, so my next look around had me checking up the upper and lower control arm bushings. Everything looks solid. Noticed something odd about the rear springs. So first image is the driver side, and the other two are of the passenger. Judging from how the right spring is sitting, does it look like it's shifted, or broke a coil???
The truck originally had air ride, then in 2015 or 2016 the original owner converted it to springs using the Monroe kit.
I'm also dealing with another issue and that's the ABS light coming on and staying on for 3 minutes after startup, and sometimes while driving down the road. Is Torque able to read the speed sensors, or is there a recommended scanner for a decent price capable of reading ABS codes? My only assumption so far, is that one of the front hubs has a bad speed sensor.
