I wasn't 100% whether or not to post this under the Brakes & Suspension section or in Drivetrain. Mods, feel free to put this in what section you feel is appropriate please
@HARDTRAILZ @Mooseman
I'd say for about a month I've had a single, distinguishable clunk noise when making left hand turns and only left hand turns from a stop or from an incomplete stop followed by a left turn. This noise sounds like it is coming from the rear passenger side, but i'm only 80% sure on that. This clunking noise does not occur at all when going over bumps you'd encounter daily on the road or even large speed bumps, which I go over daily as well. I was pretty sure this wasn't an end link clunking issue as I had just replaced all four 3 weeks ago. So I went under the rear of my truck tonight grabbing on everything that could move to see if something is loose. I checked the new end links, sway bar, panhard bar, bottom of shocks near bushings, and everything is solid and not moving by hand. I even checked all the paint marked nuts on all the end links and everything is still lined up.
The only worn out bushing/suspension components on my truck that I know 100% need replacement are the front sway bar bushings.
Now I've been looking on the old site and on ORTB about rear clunks being heard from the rear during a left turn. Apparently there can be an issue with the rear axles, more-so with the ones that have a G80 locker, just like the 8" one I have that I swapped over from a Rainier late last year. Most of the cases had axle shafts that had too much horizontal play when pulled and pushed on. Others, when taking the rear diff cover off, discovered teeth had broken off and were sitting down in the gear oil when it was drained. Another issue I read dealt with components worn out within the diff like the C-Clips or clutch packs worn down? I visually checked my rear axle and I see no signs of there being a leak, so i'm too worried there might be a lubrication issue in there.
What I wasn't able to do tonight is jack up the rear end and pull the wheels forward and back to see if there's movement. I am also gonna see if there's any play with the u-joint. Even though every time I've had my driveshaft out I didn't have any play with that. Anything else I am not thinking of here guys that could be making this clunk? I also gonna consider having my tune edited to lower the shift pressure a bit, when I go wide open throttle from a dig or low speed my truck shifts hard as hell, making the tires chirp (not the belt) into 2nd.
