Rear Brake Line Part #
tahawus84
3
Hello,
Just came over from the other site where I have been for the last 8 yrs (on and off) nice site here? Anyway does anyone know the part number for the steel brake line that goes from the abs module to the back brakes? Mine had a hole and I repaired it but would like to replace with a new line. Thanks
IllogicTC
3,452
tahawus84 said:
Hello,
Welcome!
It would be very helpful to know what kind of vehicle you have. Can you fill out the vehicle information in your profile? I really can't dig any further until I know.
IllogicTC
3,452
It's cool. I can find part numbers for the lines running down toward the ABS module, and the flex hoses to each wheel, and the line that runs across the rear axle, but nothing for the actual line that just runs front-to-back. While I'm sure there probably is a part number that includes all the bends and turns, I'm curious as to if an appropriate length of the right-diameter line could be purchased, bent (properly!!!!) to the needed design and installed.
tahawus84
3
Thanks for your help. I was going to try to bend it myself but the concern I had was where it comes off the ABS module it makes a sharp 180 degree turn and it is pretty tight. I might try it though. Thanks Again!
IllogicTC
3,452
With a proper bending tool it wouldn't be terribly by hard. By hand may be tricky, and I'm not sure whether or not it's "recommended." There's also that spot about halfway back where it swerves around something lol.
memoremix
