Yes... This is due to the loss of using Pure Lead in Solder; the alternate bonding choice being a Low Melting Point Tin Alloy Metal in Non-Lead Solder. This change in the type of Solder will... over time... allow these
Weird Crystalline Conductive Tendrils to grow and continue propagating in odd and sundry directions all over the Logic Board.
Eventually, some of them will make just the Right
(Wrong) Contacts and wind up Shorting Out the Board if these 'Metal Whiskers' touch anything that is
"HOT at All Times" completing a Power Contact Circuit and thus, result in Draining Down the Battery ... even when the Ignition Switch is in the "OFF" Position, or with the Key removed.
Whenever Automotive Clusters are repaired by any of the Reputable Repair Shops...The Technicians will first Clean the Mobo - Logic Boards with a Special Acid or Solvent to break apart, dissolve and remove all of these often Nano-Sized Metal Spikes or Threads... thereby breaking up all of the unintended conducting paths... conducive for Electrons to Flow. Then the Technicians can affect the needed repairs of re-soldering the ordinary mini-parts like the SMC's (Surface Mounted Components) right back onto the PCBs using Leaded (Pb) Elemental Solder to solve this issue:
These are often referred to as
"TIN WHISKERS" or
"Silver Migration" and they are MORE than capable of creating Unintended Electrically Completed Circuits:
These Videos come from several such inexplicable Parasitic Draw incidents with GM Vehicles well documented by Eric "O" from (SMA) South Main Auto up in Avoca, NY. During the Post Repair Phase in the Last Video of a Two Parter involving a Silverado, Eric called the IPC Repair Technician who performed this work... and the Tech was good enough to explain the aforementioned phenomena... and all of the actions he took to mitigate this problem:
Some Preliminary Videos... Chasing a Classic "Unknown Parasitic Drain" while using my
favorite Tool Kit of Choice for Diagnosing THIS Particular issue:
The Snap-On Vantage MT2400 Graphing Multi-Meter with a Snap-On Low Amp Clamp set onto the mV Scale:
Then... Watch from around 7:30 into THIS Video to witness the Phone Call Event and what Eric "O" Discovered from the IPC Tech as the actual Cause and Origin of this
"Mysterious Overnight Battery Drain":
