So did I but I really don't know.HARDTRAILZ said:I thought there was an issue of ohm difference with the factory Bose vs aftermarket, but may be wrong on that.
The Bose speakers do indeed have unique ohm ratings that are difficult to exactly match in my experience, aside from replacing them with the same Bose speakers.Matt said:So did I but I really don't know.
For everyone that will say it...
I just want to change the speakers, nothing else, yes I know all about how the Bose system sucks but I'm happy with the HU and amp.
I believe that changing the rears and the front door speakers and keeping the Bose amp and head unit is no problem. You can use Crutchfield as a reference and find replacements from Pioneer, Sony, etc. You will have to cut the factory harness off to use the replacement speakers, but I did it without problem and the sound is great. The dash, I did not try, I bought some used Bose ones to replace a cracked dash speaker because my research was that a swap with an aftermarket speaker would not work well because of the unique impedence of the dash speakers.Matt said:So did I but I really don't know.
Just because, they're not blown or bad.24v 4.2 said:The Bose speakers do indeed have unique ohm ratings that are difficult to exactly match in my experience, aside from replacing them with the same Bose speakers.
Why do you want to replace the speakers?
You likely wouldn't gain any noticeable sound quality from just replacing the speakers if that is what you're after.
If they are bad or blown, I would recommend replacing them with Bose speakers (to avoid damaging the amp and costing yourself more in the long run)
Pay attention everyone, THIS is what happens when you starve your mod bug!Matt said:Why do you want to replace the speakers?
See above for the edit. Not going to happen at this stage, but I might be able to put mix and match speakers to match the ohm's needed...just thinking out loud.Blckshdw said:Pay attention everyone, THIS is what happens when you starve your mod bug!
Matt, after you source some new OEM Bose speakers, you may want to post that info up, I'm sure someone at some point is going to want to do the same. So it would be helpful if we have a place to reference, in case it happens to be cost effective, or not.
Sib said:I was recently thinking about doing the same thing (replacing the Bose speakers). Went to an audio shop near me and when I told the guy I had the Bose he kind of chuckled. Said a lot of people want to replace their Bose. He told me to either add a sub and leave the Bose for now (possibly replace other speakers down the road with a new amp) or replace all door speakers (with amp).
I thought one of mine was going so took the door off and reseated the connector and works fine again.
So, I haven't done anything yet except turn the music up louder. Maybe if I "accidentally" blow a speaker, or more, it'll get me to upgrade sooner rather than later.
After looking around, and confirming when I took door panel off, the front doors are 8" and back doors are 5.25". Not many options for a component speaker that is not very deep to throw in the front doors.
If you decide to upgrade let us know what you did.
