02 tb 4.2 is anything supposed to be connected to what looks like a vacuum port in the front of the intake manifold. under the airbox
I have swb. but do have rear heat and ac in the back of the center consoleUnless yours is an EXT where this is used for the rear heater core diverter valve. If not, it may not even be drilled out or it will have a cap.
no I stuck a straight pick in there and it only went in about 1/4"My 02 SWB draws vacuum from that port. Did you verify there was no vacuum when the engine was running?
The only reason I suggest that is in case the back of the port is blocked but the sides would be open keeping from something being sucked straight into it.
I will check it tomorrowI've never checked that port on mine to see how far that hole will go in........ but again double check with the engine running.
