Plasti Dip Removal
Code Red
377
Little video I made while taking the plasti dip off my hood. Don't worry I plan to redo it.
[video=youtube;w4Mmnu5KHo8]http://www.youtube.com/watch?v=w4Mmnu5KHo8[/video]
Boricua SS
3,080
Ohio
yo geeds... when you bought the Dip.. what colors did they have at the store... im usually just seeing Black, Red, and White... nothing else..
im looking for something different...
Code Red
377
only black at the lowes and home depots by me
ItsOnVoy
2,401
That stuff seems pretty good when peeling, how many coats did you use?
Code Red
377
Quite a few on the top sections but the sides of the cowl were a bit thin. So the thicker the better for when you want to peel it. Course the thicker the better for holding up.
ItsOnVoy
2,401
True that!! I remember watching a video that the guy said a good 4-5 coats should do good usually.
Code Red
377
agreed, only thing is when you actual tape a area off and want to have the tape line, you can't really judge how many coats because if you let it dry and then peel the tape YOU WILL pull the the plasti up, so you just have to make your you have a thick wet coat.
madmaxdob
