Plan to replace H2 heater core hoses
The 2 heater hose’s that go to the heater core are cut an looped back onto themselves.
That being said I can only assume the plastic couplers at firewall where leaking or core itself.
I’ve never delt w/ these firewall connectors.
Before I order parts should I cobble together an reconnect the heater core to see if core is leaking?like cores do wear out right?an there a major PITA to replace?
I haven’t managed to get the heated seats working yet. So right now there’s no heat source.
So are these Dorman HVAC Heater Hose Connectors decent? I believe the H2 has rear heat so this appears to be the correct part?
https://www.rockauto.com/en/moreinfo.php?pk=9769688&cc=1434194&pt=6876&jsn=1275
I think the correct size rubber hose is 5/8”? probally 6'.
how’s this look for the quick disconnect tool? Or can I use my fingers to remove?
https://www.amazon.com/dp/B08TWW2TYL/ref=sspa_dk_detail_4?pd_rd_i=B08TWW2TYL&pd_rd_w=qxeTl&content-id=amzn1.sym.386c274b-4bfe-4421-9052-a1a56db557ab&pf_rd_p=386c274b-4bfe-4421-9052-a1a56db557ab&pf_rd_r=22TFV1EN71PHD8E97K2A&pd_rd_wg=EnccF&pd_rd_r=1fa84531-2612-4f92-ad9a-3a895b6a0abe&s=automotive&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFZSENTQ0NIWTlFUzEmZW5jcnlwdGVkSWQ9QTAxMTY5MDFXVkQ2TzBDT0xLVFUmZW5jcnlwdGVkQWRJZD1BMDUzMDk2NzI1VEY3U1NSVE02R0kmd2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWMmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1
thanks for advice
thanks for advice
