FOR SALE Pistons (with rings) and Main Bearings (All NEW) $180
Reed
21
Quantity 6
Enginetech pistons 0.50 mm oversize , including rings, piston pins and retainers. Also included are crankshaft main bearings.
Fits GM 4.2L I-6 engines with VIN S, 2002-2005 (Trailblazer, Oldsmobile Bravada, Buick Rainier, Saab 9-7X, Isuzu Ascender, and GMC Envoy)
Fits GM 3.5L I-5 engines with VIN 6 , 2004-2006 (Colorado and Canyon)
Fits 2.8L I-4 engines with VIN 8, 2004-2006
Alloy Hypereutectic
Bore Diameter 3.661
Bore Diameter 93.00
Clearance 0.0015
Compression Height 1.089
Height 0.636 IN
Oil Ring Thickness 2.50 mm
Piston Pin Outside Diameter 0.9055
Recess Dome
Second Compression Ring Thickness 1.50 mm
Top Compression Ring Thickness 1.20 mm
NEW
Save 40%. Shipping included.
Contact: reedb692@gmail.com
pm789632147
5
pa
are they still avalible, sence you bought it for a bravada, does it fit for a 2005 chevy trailblazer ls 4.2 straight 6
8,124
You would likely to have to email him, as he hasnt been on the forum since Aug 2019. His email is attached in his post.
I dont see where he said he bought it for a Bravada, But even if he did, the if your engine is covered in his list of applications above, than it will work.
tpepmeie
