Parking brake replacement
Suitcase
5
When I last replaced my pads I found the right rear park brake leaking. I believe it leaks because the shoe is worn out. I didn't change them because they were over $100. I've found them for $55 now, they do come in pairs right, it just takes two shoes, one on each side? Can you get parts to rebuild the cylinder if it's bad?
The parking brake is mechanically actuated. No hydraulic cylinder. If you have wetness it may be your rear axle seal.
Suitcase
5
How much of a job is it to replace that seal? I just changed my shocks, front axles, and struts so I have some skills. Oh yeah, changed the left seal on that axle. Do you have to go into the differential to get the axle out?
chriswilson5585
