- May 3, 2014
- 89
I learned the hard way. It is a bad idea to wait for the CEL to come on at 160,000 miles to replace the upstream O2 sensor. Not only is this bad for gas mileage, the sensor will likely seize up. Although the O2 sensor is easy to access and should be a simple job, this is how the Trailblazer O2 sensor replacement went for me:
1. After spraying a lot of PB Blaster on the sensor, I ran the engine for ~5 minutes to heat it up, and then I broke my tried and true crows foot O2 sensor removal tool on my first try. This worked for me in the past - not on the Trailblazer, of course. I figured that I probably did not let the truck get hot enough.
2. Trying to keep this cheap, I then rented a set of three O2 sensor removal tools from Advance Auto. Using the crows foot tool from this set, I felt the sensor starting to round off, so I decided to buy a half-inch drive 22 mm deep well socket. I should have tried the deep well socket first - lesson learned for all future O2 sensor replacements.
3. I cut the wires off the sensor and tried the 22 mm deep well socket. My 1/2 drive ratchet would not fit between the frame and and the socket. Should have measured...
4. I then tried using a pipe wrench on the deep well socket. This rounded the sensor even more.
5. I removed the heat shield and used vice grips on the sensor, and then a pipe wrench with a pipe extension. This just managed to completely round off the sensor. It would not budge.
6. I was desperate at this point, so I spent ~$75 on an Irwin (P/N 54125) lug nut extraction tool from Amazon:
http://www.amazon.com/dp/B001ACPRFU/?tag=gmtnation-20
I had smaller (and much cheaper) versions that worked great on other bolts, but this was the only set I could find with a 22 mm fluted socket.
7. To make this socket work, I had to break off the end of the sensor with a hammer and long screw driver.
8. I let the Trailblazer idle for 25 minutes to get it good and hot. I used the 22 mm fluted socket, and it worked great! What was left of the sensor came right out! I attached an image of the sensor and the socket I used to remove it.
9. Needless to say, the threads weren't in the greatest of shape, so I bought an O2 sensor thread chaser from Advance Auto.
10. The thread chaser turned really hard as soon as it started, so I decided to use an 18 mm-1.5 mm tap. I looked at every auto part store and hardware store nearby, but the only place I could find this tap locally was at Harbor Freight, in an $85 set. Ouch! I did not want to wait, and it would have cost me at least $30 to order it anyway, just for one tap.
11. I very carefully ran the tap into the hole using motor oil and penetrating fluid to lubricate it. I stopped when I started to feel a lot of resistance on the tap. I thought it was deeper than the thread length on the O2 sensor at that point, so I figured all was well.
12. I ran the chase in the hole. It turned much easier.
13. I turned the sensor in by hand to make sure that it would fully seat. It went it pretty smooth, so that was good.
14. I snugged the sensor with a 3/8" ratchet and one of the rental O2 sensor sockets.
15. I decided I would try to torque the sensor. Concerned about the threads, I set the torque wrench at 15 ft-lb to see how it felt. The sensor is supposed to be torqued to 30 ft-lb, so this was only half of the specified torque. As soon as I turned the torque wrench, the threads rounded out.
16. I ran the chaser back into the hole. While not as good as earlier, it seemed to go okay.
17. I snugged the sensor by hand, but when I tried a quarter turn with the ratchet, the sensor just spun freely.
The sensor is now only hand tight. The truck runs okay and the sensor does not appear to be leaking, but I am sure that this will not last very long. The local auto parts stores, hardware stores, and the nearest Tractor Supply store do not carry a helicoil for 18 mm threads, and my drill will not fit with the manifold on the vehicle. Since I have already expended too much effort on this "simple" job, I am not interested in removing the manifold. I need the Trailblazer on Monday morning, so it can't go to the shop unless I take a day off work, which I can do if necessary, but I would prefer to save my vacation days for something better.
A friend of mine told me to just wrap mechanics wire around the sensor threads and tighten the sensor into the hole as-is. I am a little nervous about doing this, but he did it on a different vehicle with success. Has anyone had success with doing this?
If not, are there any other ideas? Thanks.
