Oilfilter SAAB 9-7
farmer2030
14
Bern Swiss
Hello everybody.
I have problems with my oil filter. I ordered by type (2X) but he does not fit. do you know the problem? the masses are from the old filter. please excuse my bad english.
Kind regards
What brand and part number did you get? Do you have a 4.2L or 5.3L?
Reactions: farmer2030
farmer2030
14
Bern Swiss
Its a 5.3L
Its a MAHLE-OC614 on Swiss Web is fits for the 5.3L
The ACDelco PF48 original have
Inner Diameter Top (mm)
22.00
The MAHLE are the same Dimension to ACDelco PF48
But my old filtre have ca 19.50 mm 🤣🤣🤣
What is the brand and number on the old filter?
The part numbers you gave are correct. You could also try ACDelco PF61 or PF61E, Mahle OC1048. These are for the 4.2L however they do fit. They are just a little longer and I use these in my 5.3L for the extra capacity.
Are you able to get other brands of filters?
farmer2030
14
Bern Swiss
Unfortunately, there is no inscription on the old filter. Thank you for the info.
yes I could also order other brands. Unfortunately, these are all European models
farmer2030
14
Bern Swiss
Hello everybody.
I think the search has an end. The oc1048 does not exist in Switzerland. The seller has given me but a similar. I hope it works. I thank all involved for the help. Greetings from Switzerland
Joe102938
