Oil leaking at end of Oil Pressure Sending Unit
Capote
24,227
Atlanta, GA
I just was out at my truck and I noticed a 1 sq foot oil spot on the ground. Popped the hood and I see a droplet of oil dripping out of the end of the oil pressure sending unit about every 3 seconds. The green clip is broken at the part where it secures around the stub on the end of the sending unit. When I pulled the wiring harness out of it, it leaked even faster, barely staying in as it is. I checked my oil and it's half a quart low. Looks like a pretty fast leak. I'm gonna try and crossover two zip-ties as a band-aid, that's the most I can do right now. I don't want the connector falling out.
Edit: I looked up the connector, looks like you have no choice, but to cut the wires and put in crimp or solder in a new one. No parts stores carry this, so gonna have to next-day ship with RockAuto.
https://www.rockauto.com/en/moreinfo.php?pk=3478179&cc=1424281&jsn=10798
littleblazer
9,265
Get a new sensor. :2thumbsup: oil is supposed to stay behind that.
Reactions: Redbeard and Capote
Yeah sounds like the switch itself is busted. Kinda like the CPAS connector leak.
Capote
24,227
Atlanta, GA
*sigh* i'll add that to that cart. Did next day shipping...
Capote
24,227
Atlanta, GA
Capote
24,227
Atlanta, GA
Stopped the leak for now. Gotta another problem with semi-rough idle and a really loud lifter sound. This thing was running great, now its starting to act up like my old motor.
That might get more involved. Might as well start a new thread for that problem.
Capote
24,227
Atlanta, GA
I have a few ides what could be the issue, i'll just troubleshoot and make a thread if i'm not getting anywhere.
I'm a tad confused,this is on the batblazer? Didn't your engine die or already got a replacement in there?
Yes we swapped it out for the other one I had in my storage unit. That one was performed with some OCD maintenance, so my current issue most likely is an accessory problem. But I don't want to get off-topic on this thread.
Don't you have the sender/switch from the other engine? If it's still good, just swap it out. That's where the oil is coming from. The connector is designed to keep water out, not oil in.
Capote
24,227
Atlanta, GA
That one was leaking worse than this one.
Ah well, a new one it is.
evenson1
