I have a 2004 Rainier 4.2L 2wd. The left front wheel sensor went bad so I replaced it. One of the symptoms was that when you pressed the brake the abs would kick in regardless of speed or pressure on the pedal. That solved the ABS light and that problem. BUT now when coming to a stop or at low speeds, like slowing to go over a speed bump in a parking lot, it does the same thing. You get the vibration in the pedal and a sound best described as a grinding/groaning. Pads are all fine etc.... its definitely the ABS kicking in.... No ABS light this time though. Heard about a ground for the EBCM? or maybe its the EBCM itself...IDK.....anyone else with this one?
