No crank help(solved)
Failblazer89
3
Oregon
First off new to the forum.
Ok so it's a 2004 trailblazer LS with the 4.2L no mods.
I went out to start it forgot something turned it off so the engine ran for 3-5 seconds. Came back tried to start and no crank, lights on the dash come on but that's it not even a whimper from the starter. Other weird thing is the windows and doors don't work neither does the key fob. Radio doesn't work. You can set the clock and eject the cd but it won't turn on. You can however roll down the back windows using the back window switches. I've already changed the:
Battery
Negative cable
Megafuse 125a
Ignition switch
Starter relay
I've also gone Thur and checked grounds and check connections. Any thoughts or suggestions am I missing something. Or is the pcm fried?
Failblazer89
3
Oregon
I solved mine. It was different than other people's. mine was the radio. Pulled the fuse under the backseat and got the PRND321 before there was no line, and it also started right up all the other faults went away
So the radio was FUBAR`d and screwing up the data bus? First time I've heard of the radio preventing the engine from starting.
Mynamesjeff
