I too admire the designs of the original
"Double Acting" Two Stroke (Diesel Engines) designed as early as 1899... for Diesel
(Yup... By THE MAN Himself) Powered applications beginning with two "Meek and Mild" variants at the Turn of The Nineteenth Century. The first one being a 12HP version and later a milder 7 HP version.
What is THE Advantage? A Two Stroke Engine produces its POWER STROKE within 360 Degrees of Crankshaft Rotation... Whereas a Four Stroke Motor requires 720 Degrees to accomplish the same thing.
However, when their country (Germany) was up to its neck in the First World War THEY Started with their Militant Kaiser around fourteen years later, the
"Krauts" had perfected one particular In-Line Six Cylinder Diesel Motor that was Producing well over 12,000 HP...
and they even had Diesel Engine Variants for Powering Aircraft.
So the Japanese...
clever though they may be... are coming very late to the party on THIS one....
(Wakane Mas Ka?) and
these "Old Boys" did
NOT require any "Iridium" Spark Plugs neither, because when Air is Compressed to 16-18 to 1 Compression Ratio...
it Super Heats...and as soon as Diesel Fuel is injected under
VERY High Pressure into the Hemispherical Domed Combustion Chambers... it
instantly DETONATES at near TDC and creates that familiar "Bag of Marbles" Rattling Noise from the High Pressure Shock Waves that all Diesel Motors create in this odd
manner of Diesel Powered Combustion ...carrying with it a VERY Heavy Penalty of using a Dirty (BUT.. Energy RICH) Carbon Laden Fuel Consumption in general as a result.
en.wikipedia.org
"There is Nothing NEW ...Under The Sun..." -- Ecclesiastes 1:9
