Need help figuring out why the Trailblazer won't start after replacing radio.
What did you replace it with? Another factory radio or aftermarket? Use an adapter or interface?
Check all your fuses, under hood and back seat. Not just visually but with a DMM or test light. Check ignition switch output.
Does it crank and not start or it doesn't crank at all? This question will determine the path you'll be following.
Reactions: gmcman
Scobee
5
Texas
It won't crank and I now have to push a little button in to gave the key out. With it running I pulled the aftermarket radio out and put the factory radio back in. So all the lights come on when I turn the key but when I go to start it nothing happens.
10,689
This is usually a sign of a low battery. Can you verify the voltage you've got? What happens when you connect a charger, jumper box, or try to jump start it?
Reactions: gmcman
How was the aftermarket radio wired?
Did it have a plug-n-play harness, or did this involve cutting wires?
Did any wire accidentally ground out? Any sparks?
I would start with the 125A maxi fuse in the front of the fuse box and do what Mooseman suggested, start checking fuses, both the underhood fuse box and under the LR seat.
Hopefully you didn't get a short and damage the BCM.
DurangoJack
