monroe strut - a bit long?
blurry
22
I just installed a Monroe sensa-track strut part #71341 in the front of the 02 trailblazer. I had to compress the spring to get the strut arm to fit.
I used the old spring, yellow bumper and dust shield. The top nut has about 1/2" of thread showing with the nut on
am I missing something?
Assuming you compressed the spring sufficiently when you put the top nut on, and the nut is snug to the end of the threads on the shock rod, you're OK. Typically, if you do one side at a time, the anti-sway bar will limit the downward motion of the lower control arm a bit.
What's bad is if you try to use the nut to compress the spring the last 1/4-1/2". That's not going to work, and will leave the nut loose to work its way off later.
blurry
22
I might not have run the nut on the top of the shock to the bottom of the threads. The oem didn't look like it was down all the way either.
Both sides of the fronts are on stands. I still need to do the sway bar links so the truck is still on the stands.
Should I pull the strut and tighten the upper strut nut till it is out of threads?
fadyasha
1,134
I've had monroes since 90K ago and no problems even with a lift. Wish could get bilsteins here though lol
syntaxmaciah
