- Dec 18, 2013
- 20
I have an 05 ext. with a misfire I keep chasing and am not sure if I should just let it go. Started with a misfire on #2, light would come on then off shortly after on it's own. Changed new and correct plugs, it was fine for a file then same thing. Light would come on then off, no flashing and would come on normally when sitting at ideal. Then it changed to random misfires. Moved plug and coil, still random then #2. Tighten intact bolts, which were not tight and I've read is a common problem. Cleaned throttle body, wasn't bad but still did, added fuel inject cleaner. I'm still getting a code set but the light isn't coming on all the time. Could this be something more internal be going on? Is it time to say good by? All other maintence is up to day it has 110k. Should I not check until the light comes on and not worry about it or what?
I have the full version of the torque, which is what I'm using to read and clear codes. Does anyone know if there is a way to see cylinder firing info?
any ideas would be great, really starting to mess with my mind
