max tire height again.....
fiddler
1
i have a 2008 denali envoy and was wondering what is the tallest tire that can be used without any modifications/rubbing ect.? (18 in wh.)
You need to look at the upper ball joint, there isn't much clearance there. Therefor you need to keep the tire height about the same as stock. Stock is 29.57 inches. I currently run Michelin Cross Terrains at 275-55-18 with an overall height of 29.90 inches and I don't have much room to spare but there are no issues and of course as the tire wear the gap gets bigger.
Try this site to compare tire sizes
http://www.1010tires.com/tiresizecalculator.asp?action=submit
I'm not sure a 30.5 inch tire would fit here but if the other fellow says it will I will go with what he says. :undecided: That would be 1 inch taller than stock with 1/2" on each side, real tight.
Generally 30.5", but many tires are larger or smaller than their "nominal" size would suggest. No substitute for finding a tire shop that will do a test fit. Definitely go under there and look at the relationship of the tire edge to the upper ball joint mount to see the issue.
filthycasual
