Lower ball joint stud spins / can't tighten nut
6716
822
What am I doing wrong here?
Thanks
BRomanJr
371
Thanks
I use a jack under the rotor to lift the spindle up onto the ball joint shaft and bottom out the taper, this will lock the tapered parts then the shaft should not spin.
Hypnotoad
1,584
The jack will probably do the trick. If you are using a jack and it's still spinning, try tapping the knuckle into the taper and see if it'll catch. Use a 2x4, rubber mallet or something soft so you don't damage anything. I had to do this on a different car, but my trailblazer had no problem.
6716
822
That was the trick. I put the jack right under the knuckle.
A million thanks!:thumbsup:
Hanns Carrasco
