- Oct 13, 2013
- 18
I don't see how that could be possible. In order for the "catylist" cycle to be completed the 02 sensor would have to pass the pcm's test cycle, that is what it is for. I've never seen a cycle complete on a gutted cat for any length of time before it set the code. The only way you could have passed is that emissions testing allows (depending on the year of the vehicle) 1 or 2 Readiness monitors to be incomplete and still pass the inspection. You got lucky to get in there at just the right time.2003trailext said:I disagree. nobody told me anything thats what i did to pass inspection. i reset the ecu drove about 50 miles then got it inspected. day or 2 later the light came back on. your not tricking the emission computer just dont have the code yet. If you try to reset ecu then get it hooked to emissions computer it wont read/pass because it will know it was just reset. You have to drive atleast 50miles or so preferbly highway before a emission computer will read/pass ecu after its been reset. people do this all the time in the lil poor city where im from.
it tried this and have one up there now. might have to try and squeeze to in there in see if that helps.Hypnotoad said:Back when we had emission testing here, I knew 2 people that passed emissions with a gutted cat. They would check if the cat was physically on the car with a mirror, and if the engine was burning clean enough you could pass emissions without it.
Google turning the check engine light off with spark plug foulers.
i can tell you from first hand experience when i reset my check engine light i can drive atleast 50+(i drove over 100+ before triggering at times) miles before it comes back on.BlazingTrails said:I don't see how that could be possible. In order for the "catylist" cycle to be completed the 02 sensor would have to pass the pcm's test cycle, that is what it is for. I've never seen a cycle complete on a gutted cat for any length of time before it set the code. The only way you could have passed is that emissions testing allows (depending on the year of the vehicle) 1 or 2 Readiness monitors to be incomplete and still pass the inspection. You got lucky to get in there at just the right time.
thanks i guess i will try and squeeze another one in there and hopefully no more check engine lightBlazingTrails said:It only works with 2
I've heard of people stuffing the fouler with steel wool to trick the computer too.2003trailext said:it tried this and have one up there now. might have to try and squeeze to in there in see if that helps.
