- Jul 9, 2014
- 3
Recently I picked up a 2003 Trailblazer EXT LT 140,000 miles and a brand new GM transmission. Right from the first day I noticed that when I would tap the gas after the truck was at a warm idol (Aprox 600RPM's ) the engine will almost stall for half a second before reving up. I've also noticed that if I roll up to a stop and don't slow all the way down before getting back on the throttle the truck doesn't seem to down shift unless I almost put it to the floor.
Here is some background:
No codes have registered. I've replaced the catalytic converter and downstream o2 sensor (due to not being able to remove the old one). I've also replaced the spark plugs with OEM delco. When replacing the plugs I noticed that the valve cover is leaking around the plug wells. I plan on replacing this soon. I've also noticed a leak or crack at the exhaust manifold.
I'd like to figure out what this issue is. Any help is appreciated.
