Just got Torque pro -TID:$05 CID:$0d - Failed
richphotos
298
St. Louis Park, MN
I just got torque pro, not too firmiliar with this but I was running the checks and everything looks good but a few things.
The truck runs perfectly, no stuttering or misfiring. No CEL
Is this stuff normal? (I am new to this stuff)
If there is anything else I can add to this thread from Torque, let me know.
(there are also no stored DTC's either.
Test report:
TID:$02 CID:$04
- Lean to Rich sensor threshold voltage(constant)
Test incomplete or dependant test failed
TID:$02 CID:$06
Min: 32,818
Test result value: 32,818
PASS
TID:$02 CID:$11
Min: 80
Test result value: 80
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,868
Test result value: 32,868
PASS
TID:$02 CID:$60
Max: 33,068
Test result value: 32,849
PASS
TID:$02 CID:$62
Max: 32,758
Test result value: 32,701
PASS
TID:$02 CID:$66
Max: 32,889
Test result value: 32,693
PASS
TID:$02 CID:$71
Max: 32,838
PASS
TID:$02 CID:$72
Max: 32,758
Test result value: 32,568
PASS
TID:$05 CID:$01
- Rich to Lean sensor switch time(calculated)
Max: 65,535
Test result value: 11,111
PASS
TID:$05 CID:$02
Max: 65,535
Test result value: 17,639
PASS
TID:$05 CID:$03
Max: 65,535
Test result value: 8,056
PASS
TID:$05 CID:$04
Max: 65,535
Test result value: 15,972
PASS
TID:$05 CID:$05
Max: 8,313
Test result value: 3,875
PASS
TID:$05 CID:$06
Max: 4,813
Test result value: 2,688
PASS
TID:$05 CID:$07
Min: 40
Test result value: 78
PASS
TID:$05 CID:$08
Min: 40
Test result value: 81
PASS
TID:$05 CID:$0b
Min: 24,000
Test result value: 24,160
PASS
TID:$05 CID:$0c
Max: 9,600
Test result value: 480
PASS
TID:$05 CID:$0d
Max: 150 Min: 65,386
Test result value: 19
FAIL
TID:$0c CID:$60
- Misfire counts for last/current driving cycles(calculated)
Max: 32,998
Test result value: 25,772
PASS
TID:$0e CID:$11
TID:$0e CID:$12
End of report.
richphotos
298
St. Louis Park, MN
Here is an updated one that I just got today.
In this one I put it to the floor a couple times from stop lights while the tests were being performed. Same results.
Test report:
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,818
PASS
TID:$02 CID:$11
Min: 80
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,868
PASS
TID:$02 CID:$60
Max: 33,068
Test result value: 32,853
PASS
TID:$02 CID:$62
Max: 32,758
PASS
TID:$02 CID:$66
Max: 32,889
PASS
TID:$02 CID:$71
Max: 32,838
PASS
TID:$02 CID:$72
Max: 32,758
PASS
TID:$05 CID:$01
Max: 65,535
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
PASS
TID:$05 CID:$04
Max: 65,535
PASS
TID:$05 CID:$05
Max: 8,313
Test result value: 3,750
PASS
TID:$05 CID:$06
Max: 4,813
Test result value: 2,750
PASS
TID:$05 CID:$07
Min: 40
Test result value: 64
PASS
TID:$05 CID:$08
Min: 40
Test result value: 70
PASS
TID:$05 CID:$0b
Min: 24,000
Test result value: 24,640
PASS
TID:$05 CID:$0c
Max: 9,600
Test result value: 4,800
PASS
TID:$05 CID:$0d
Test result value: 16
FAIL
TID:$0c CID:$60
Max: 32,998
PASS
TID:$0e CID:$11
TID:$0e CID:$12
I am not worried about it, I am just ultimately trying to understand what these numbers mean and what the FAIL one is.
I guess this would be I/M Readiness tests? If that's the case, it can take a few drives or a long enough one to get all the tests completed.
Reactions: richphotos
richphotos
298
St. Louis Park, MN
I believe so, its log of the test results.
I assumed that the ones that did not complete is because I did not do a full drive cycle. Could that be why the one failed with such a low number?
TID:$05 CID:$0d
FAIL
I am so new to all of this obd2 stuff, I have been trying to learn it all on my own but this confused me. Thanks for the answer and help!
Yeah, those are the tests that the PCM does and tells the E-Test software if it passes. It will eventually pass unless there is a problem and it will light the CEL with a code. Unless you get a code, don't worry about it.
Chris Moore
