I6 underhood service specifications
MAY03LT
Delmarva
Oil grade: 5w30 (All temperatures)
Oil capacity: 7qts w/filter
Battery:
02-09 Group 78 600CA
Alternator:
150A
Spark Plug Torque:
02-09 13ft/lb
Spark Plug Gap:
Note - Posted for reference only. Gapping Iridium plugs is not recommended.
02-04 .050"
05-07 .042"
08-09 .040"
Fuel Pressure:
02 48-54psi
03-09 50-57psi
Oil Pressure (at sending unit, engine warm, MINIMUM):
12psi @1200rpm
Firing Order:
153624
Compression:
215psi - *Lowest cylinder must be more then 70% of highest cylinder
Injectors:
02-09 11-14 ohms @ 50-90°F
Map sensor:
02-05 More then 2.0v at idle less then 4.2v at WOT
TPS1:
02-06 Idle less then 4.67v WOT more then .27v
07-09 Idle .32v WOT 4.75v
TPS2:
02-06 Idle more then .27v WOT less then 4.67v
07-09 Idle .25v WOT 4.59v
Coolant capacity (quarts):
02-04 14
05-06 10.8
07-09 9.7
03-04 EXT 15
05-06 EXT 13.8
Cooling system test pressure: 15psi
Radiator Cap Relief: 15psi
A/C data:
Refrigerant type: R-134a
Compressor oil: PAG 46
Capacities (Refrigerant/Oil):
02-03 1.8lbs/7.4oz
04 1.9lbs/7.4oz
05-06 1.9lbs/8.0oz
07-09 1.9lbs - w/TPS 8.0oz (first design) w/oTPS (second design) 6.0oz
02-03 F/R 2.65lb/8.45oz
04 F/R 3.0lbs/8.45oz
05-06 F/R 2.65lbs/8.0oz
07-09 F/R 2.65lbs - w/TPS 8.0oz (first design) w/oTPS (second design) 6.0oz
Note: TPS - Thermal Protection Switch
Source: MOTOR spec guide 2011 version
MAY03LT
Delmarva
Belt routing:
SWB - 91.5" belt
LWB - 90.5" belt
Reactions: mrrsm and Redbeard
JRTAHOE
848
This thread delivers :cool:
Regulator
2,496
Great information here, thanks a bunch!
How about adding fluid type and capacities for the other serviceable parts. Transmission, Transfer Case, Front Differential, & Rear Differential.
MAY03LT
Delmarva
Thanks man. I am going to list those in the "Engine and Drivetrain" forum since those specs can be used for the 4.2/5.3/6.0.
Wooluf1952 said:
Nice to have it all on one page. :wootwoot:
That's the plan!:cool:
Well done! should defiunitely help alleviate some of the simpler questions.
Regulator
2,496
So I have been starving the engine by only using 5 quarts of oil for the last 230,000 miles? :raspberry:
ItsOnVoy
2,401
This is great and will be a big help!! Thanks :biggrin:
JPZ
Thanks. I got a belt that I need to put on and I didnt notice the diagram on the fan shroud. That's gonna help.
Joe D 04
26
How about back pressure for the exhaust?
I'm thinking about testing to see if I have a clogged cat and buying my own gauge
Whoa, I never realized there was that huge a coolant capacity difference between the various years. I could see a little bit of a difference on the 06+, but a whole gallon? Weird.
Mypetropig
226
So what are TPS 1 and TPS 2 for and where are they located? This article says that the plug gap for my 03 should be .050" and mine I believe were pregapped at .043", will it change anything if they were at .050"? Lots of info here and it gives me some things to check tomorrow.
Wooluf1952
2,663
Milwaukee, Wisconsin
Hover your cursor over the TPS and it will show the meaning.
One is on the gas pedal and one is in the throttle body.
IIRC, the .043" is an up-date.
There are TWO sensors in the throttle body, and the shop manual calls these the TPS. There are another two sensors on the Accelerator Pedal assy, and these are typically called the APP (Accel Pedal Position) sensors. The reason for two sensors on each is because their positions are compared by the PCM and if they don't agree, you go into REP (reduced engine power) mode to limp home or to the side of the road so we don't end up in a runaway condition.
Mypetropig
226
Cool trick with the cursor. On some of these items would it be easier to check with a volt meter or a scan tool such as one of these,Actron® or Actron®.
Wooluf1952
2,663
:redface: I stand corrected.
Spalding1028
60
I'm not sure who recommended against gapping iridium spark plugs, but it's perfectly fine to gap them as long as you use a wire type gapper and not the slide/coin type.
Wooluf1952
2,663
I think the biggest problem is people prying in the gap itself and breaking off the tiny piece of Iridium and, as you stated, using the flat style gapper.
Also, the AC Iridiums come pre-gapped with a shield to prevent the gap from being damaged in shipping.
hancock
5
I have a 2006 envoy 4.2. Is that AC Delco part that I should # 41-103
Getting new plugs for 2006 envoy 4.2. I'm getting AC Delco but can't remember what part# was recommend. 41-103?
dmanns67
32,979
Ohio
AcDelco 41-103 is the correct spark plug to use with the I6.
Not for the plugs. 41-103 is a new number.
And the manual often goes missing so it's useful to have it available elsewhere.
dmanns67
32,979
Ohio
My Chilton Repair manual does not even list 41-103 for the I6. The manual listed a completely different spark plug number. I had to pencil-in the new AcDelco plug number.
Wooluf1952
2,663
Right. The Owners Manual for my 2003 Envoy I6, calls for AC 41-981. I've changed to the AC 41-103 Iridium.
dkvasnicka
366
Czech republic, Europe
Does my 06 Saab 9-7X (which is not XL but has rear A/C) also fall into the "05-06 F/R 2.65lbs/8.0oz" category or is it 3 lbs? A shop filled my A/C up to about 850g of refrigerant (as I now found out from the invoice) and my A/C doesn't blow cold (the snowflake symbol doesn't blink though).
Mounce
13,667
Tuscaloosa, AL
Check the stickers in your engine compartment. One of them will specify refrigerant type and quantity required. That is likely the number they went by when recharging it.
Verify whether or not the compressor clutch is engaging. If it is not and 850g is the amount listed on the sticker, take it back and have them check it again.
- I'm assuming your ac worked when you left the shop but stopped working after? No way I would leave the shop with it not blowing cold.
dkvasnicka
366
Just wanted to edit my post to say I went to look for the sticker and found it :smile: It's 2.65 lbs. It seemed to work when I was leaving the shop but it was quite cold outside (definitely not A/C-requiring temps) so I probably didn't judge it right.
dkvasnicka
366
So I'm scheduled for fillup of the A/C but they are telling me it's not just the amount that causes it to not work at all. He told me that even with that 50 % of refrigerant it should blow cold, albeit not ice cold. Is that true? Last time it took a year for the refr. to leak out so there definitely is a leak... I just hoped it didn't get worse :sadcry:
Another member also believed he had a rear A/C and overcharged it. Use the lower amount for the single system.
Agent_Smity
