I want to add a real oil pressure guage. Suggestions please.
c good
534
Hi Everyone,
Hopefully my Berryman's soak has solved the problem of my low oil pressure at idle. I would like to add and actual oil pressure guage. What is the best way to go with this? I've heard of electronic, and I'm familiar with the old school actual oil line to the gauge also. Any suggestions would be appreciated.
TJBaker57
2,907
Colorado
There is a rather long discussion over here...
7,784
Recommend using the Bosch Automotive Copper Line Kit or similar quality Kit over using Nylon for the Oil Line Run... and add in 3-4 coils right where the Line passes through the Firewall Grommet to act as a "Spring Shock Absorber" to avoid getting any Flex-Fractures in the Oil Line occurring from a combination of thermal expansion-contraction and the normal Engine rocking motions and movements on the Motor Mounts & Transmission Mount:
Reactions: Tankcruiser
Mektek
656
FL
These days there's no reason to install an old fashioned "steam gauge" except for temporary testing.
Check the other thread for an updated progress report.
Joe102938
