How to replace Vent Solenoid (I6 Trailblazer)
tbuckalew14
380
Time: Less than 5 minutes
Cost: give or take $25.
Tools: Flat head Screwdriver, Eye protection(unless you want little rust particles in your eyes), Gloves(I didn't wear any, but again, you're working on near rusty metal it should be a no brainer)
Locate the part on the vehicle.
The vent solenoid is located toward the rear of the gas tank. Photo taken directly below.
This photo is taken from the side.
Step 1: Remove plug.
Step 2: Use screwdriver to press on the little nubs.
View of the hose clamp once it's removed.
Step 3: Use screwdriver to unclip metal bracket, and then just slide the part out.
Reverse the directions to put the new piece in(cross your fingers and hope that gets rid of the engine code)
Thanks for this! Just to have one stop shopping on one thread - what was the RPO code that led you to changing this?
Steveinfl
62
I needed this replaced and broke down for the 100 dollar dealer diagnostic. They quoted me ~$450 to replace it claiming that the tank needed to e dropped and such. It really is an easy job to change it out. I had the generic loose gas cap code. P0014? Not sure of the number anymore.
tbuckalew14
380
I was getting p0455 large leak or something to that effect. Tried replacing the gas cap, code was still there. changed the vent solenoid and no more code...it's only been a day though, so we'll see.
Canary2323
346
I had same problem git new gas cap and nothing, git quoted 300 to change and did it myself for 20$ and no more fault codes.
dmanns67
32,979
I had the same thing. P0455 and P0449 are evaporative system gross leak. They are commonly tied to the vent valve or purge valve. If you are lucky, it is just the gas cap. Smoke test is useful if you are not sure which one needs replaced.
Great article :thumbsup:
woody79
351
Great article!
Quick question..... once the solenoid is replaced, should the check engine light go out right away after starting her up? Or is there a set amount of miles/engine starts that need to be met before the light goes out?
Thanks in advance.
The code I as getting was P0449. There was only that code. I haven't taken it back to advance auto to have the code read again yet.
Canary2323
346
woody79 said:
Great article!
Thanks in advance.
No it takes a couple cycles.
woody79
351
Thank you! :thumbsup:
I will try that later.
clayton8633
