How to Flush your Brakes Completely
dogfish246
42
Hey guys,
This is my latest video on How To Flush and Bleed Your Brakes. Although I used my pickup truck for this video this will apply to any car or truck so I thought sharing it here would be helpful. Brake fluid absorbs water so after about 3 years you should flush them. While I know of no one who flushes their fluid that often I figured after 14 years I should flush them out lol.
So when was the last time you flushed your brake fluid? I am curious how often others do this...
Let me know what you think!
**Also, if the video was helpful, give it a “thumbs up” on YouTube (it helps me out, thanks)***
https://www.youtube.com/watch?v=n1NvtUwfRJc
07TrailyLS
423
Toledo ohio
Awesome vid. Never ever flushed brakes before. Never had any of my cars long enough to. This is the first how to I watched and it was amazing. The clarity and in depth was great awesome job dog
Rogue92
83
Subscribing...thanks for making!
MAY03LT
Delmarva
Never, or when a leak is fixed and the system is refilled, whichever comes first.
triz
746
Great video. The only additional step I took was removing the reservoir and cleaning it out with brake cleaner. There was gunk stuck to the sides of the plastic. I did that to really eliminate the dirt. Otherwise awesome video!
dogfish246
42
Thanks man! I hope I set high standards to the "how to" videos on YouTube lol!
Subscribed. Great video.
Thanks! I appreciate the feedback!
Thanks and no problem!
That is a common answer. Seems like not many people do this service at all unless there is a problem.
I flushed my brakes at 70k miles and around 138k miles after I installed my BrakeMotive d/s rotors and ceramic pads.
That is probably how often I use to flush my brakes. I never really did it unless the fluid was dark or I had to service my brakes.
Thanks for the tip! I really tried to keep it simple. If I was to remove the reservoir it would be a lot more complicated for people and in reality, it wasnt dirty enough in my book to do that. But that is def a good tip for someone who has a dirty master cylinder! Thanks!
I flushed mine when I installed all new brakes and rotors. I usually only flush them if the fluid is discolored.
That is a good method. You figure that is ever 3yrs or so and you are already down there working on the brakes!
Good video. Well done and informative.
Just one comment. In the past, when I tried to do the one person method, my brakes would get soft because air would get sucked in by the threads of the bleeder. Sometimes using teflon tape helped but only if I didn't tighten and back off the bleeder. So I just don't bother with it and only use the two person method. I even got my kids to do it for me.
This was quite a few years ago (70's, 80's cars) and quite possibly the threads were coarser that would allow air in. Maybe with the finer threads, this has been eliminated.
dogfish246
42
I have never had this problem. Maybe the threads today have much better tolerances? Or maybe you loosened the bleeder valve a little too much (I just crack it). Who knows. Interesting though.
I do remember the threads being much coarser so that probably had something to do with it. I just gave up using it.
ghenny440
368
Dude this is awesome i have been subscribed for like a year! And Didnt know it was one of our guys[emoji106]
Reactions: Rogue92
10,687
Well at the time you subscribed, he wasn't one of our guys yet. He just joined us last week!! :raspberry:
Reactions: ghenny440
ddgm
152
Back in the day, the procedure was to attach one end of a small hose to the bleeder and the other end into a jar with brake fluid in it. As long as the tube was immersed in the brake fluid, no air could enter the system.
Doug
mubai
321
I know this is an old thread, but was there a noticeable improvement in braking or brake feel?
Depends if there was air in the system to begin with. There might be an improvement when they get hot and the fluid was so old that it lost high temperature resistance to boiling.
Look at it this way; it can`t hurt.
mubai
321
Thanks Mooseman.
So it looks like all i need is a clear plastic tube, container and brake fluid. Fill the container with some fluid, insert tube, other end on the valve, open valve and press the brakes.
Adungyyy
