Jkust said:There are already many threads on this. Literally all over with pictures and diagrams.
GregT said:Anyone using the hid headlights. I been looking around for some. Whats a good name? What watts should I get?
blazinlow89 said:I have kensun (Amazon.com) 6000k for both highs and lows. Nice and bright and works pretty good.
GregT said:Sweet how long have you had them installed now. Did you put them in your self. If so How easy of an install was that. Do you need to kill the day time running lights feature.
GregT said:I think I'm just going to stay stock headlights. I see too many bad things about them. Bulbs going out or ballasts. I like my day time running lights (safer) I also think it would look silly with brights on. Yes I know I may not even need them since there brighter. I think I might just put in Philips clear vision in Maybe. Right now I have other things I need to buy for my RV.
blazinlow89 said:^ what he said.
Just reading Kensun offers a 2 year warranty on all products. I have a spare set of OEM bulbs in the storage compartment in the back, so if something does happen Im not SOL. Also usually the equipment does not just stop working, there is usually a warning sign. flickering, extreme dimming, extreme color change, loud buzzing sound (than normal), etc.
GregT said:just not convinced I still have my original halogen bulbs in my 05 never replaced. Seams like hid bulbs just don't last as long. I saw a post or two of people switching back to halogen after hid install what's the point.
ItsOnVoy said:Where did you see post about things like that? The prius forums? haha HID's outlast a halogen no matter what!!! Like I said if your ballast are good and you do not touch the bulb and get a good brand they will last you! DDMtunning or VVME, those post you read where prob people that go get some cheap brands or brands that are not well known so yeah there risky and that will happen with them. Do some research on google on the HID's because HID's first off are 35W which is less then a halogen so that already says more life, HID headlights are also less of a strain on your vehicle’s battery power, as they consume over 30% less energy than halogens and are over 30% brighter then a halogen. Furthermore, HID bulbs produce less heat during their operation so I do not see how all that makes them not last as long. Just do not touch the bulb and if you install them right your fine man! It is up to from here if you want them, I recommend them because I was in your shoes before I got mine and i bite the bullet and glad I did so up to you now
ItsOnVoy said:I forgot to mention that if you do get some then look for slim digital, those last longer here are my lights if you this helps or not
GregT said:Could you tell me what kit would be good for DDM Tuning or vvme for an 05 trailblazer ls
and what and where will I find a DRL killer.
MAY03LT said:This is the kit I have now. Actually, I have one of their kits for the lows and one for the fogs. Like I said in the thread that you linked, I have a problem with the relay harness that I've had since '07, not with their kit. The kit is on it's third year, I got two years out of the first low beam kit it I got from 3bspec.
Disabling the DRLs is something that I feel is DIY. There are two ways that I have done it in mine, both cost under $10.00. First was making it so the lows only turned on with the headlight switch - no drl, no low beams during perimeter lighting, and no low beams when the auto lights came on. Second was no drl, no perimeter lighting, with low beams when the auto lights come on. Both worked great. The only problem with the autolights is that if it's dark out, the lows will come on when the key goes to "run" and will stay on when the engine is cranking. To get around this, I did the BO TIE SS switchable auto light deleter, which included wiring a toggle switch and resistor to the sun sensor in the dash.
GregT said:I thought there was a simple drl killer kit
kardain said:There is, its a relay that taps into certain wires at the BCM. 5 minute job. 10 if you want to make it look clean.
The laptop I have the instructions on had the screen burn out recently... Checking to see if I stashed them elsewhere.
GregT said:Yes that what I was thinking of would be great to get. Thought there was a member on here that sold them I reed it some where in here.
4wVoy said:
GregT said:Right now I don't have the money for them anyways.
GregT said:I wanted the kit that jettstream sold I don't see where you can buy from him?
Blckshdw said:Another option, would be to buy an HID kit from TheRetrofitSource. Most people primarily buy their projector goodies from there, and their HID kit is a bit pricey, but I've heard their customer service is top notch, and it's hard to beat a 5 year warranty.
ItsOnVoy said:DDM has a life-time warranty lol Those kits are really pricey, might as well go to a stealership or something
GregT said:Wow ddm rocks awesome prices and lifetime warranty. I been looking at these http://www.ddmtuning.com/Products/DDM-HID-Kit-Slim-Ballast-35W-or-55W
My question what bulb type do I need.
kjkim93 said:If you need DRL, go with V-LEDS 9006 Module for $10. You will be able to use DRLs with the HIDS. I have both the cap.mod and the module. And both work great.
Blckshdw said:In different vehicles, or both in your TB?
GregT said:When using the V-led's does that convert it too 100% power all the time then too be honest running 100% daylight headlights is just plain silly. That's why there reduced power. I have remote start on my TB lights turn on briefly then turn off too parking lights only. Will the auto light sensor still work?
Blckshdw said:With HIDs, you can't run them at the 70% pulsed cycle that our vehicles output. You either have to run them at 100% or 0%, otherwise you'll burn out your ballasts or relay harness from the repeated on/off/on/off signal from the DRLs.
