so I decided to fix the two wires on my breakaway switch, they had bare wire showing so i removed the crimps, soldered them and resealed them up. then I put a new breakaway battery in, then afterwards got in my truck and my break controller is flashing S.H. I looked in the manual and it says the prodigy detects a brake short during idle condition. I thought maybe i hooked up the breakaway battery backwards so i reversed the neg and pos wire but that didnt stop the flashing S.H on the controller. so i disconnected the trailer from the truck and prodigy is still flashing S.H., did i screw up my prodigy break controller by cutting and resoldering my breakway wires while having it all hooked up to the truck? (the power on the truck was off when i did the work) everything was working 100% before i touched the 2 wires and replaced the battery, or any other thoughts on why the prodigy is flashing S.H.
thanks for the help
just to add, Im not sure if my breakaway switch even worked before as the original battery was dead. once i hooked everything up I pulled the plug out of the breakaway to see what happens and the only thing i could hear was some ticking noise from one of the brake drums. not sure if that is what is suppose to happen when the breakaway plug is removed.
thanks for the help
