Hello, to begin I have searched and found some good info...
02 TB 170k miles, seen better days, factory radio in back seat replaced by prior owner with amhu that doesn't work/power up. Good battery and alt. Got it a year ago and has mostly been parked but started and moved in the driveway every week or two.
A few days ago I had to drive it, drove relatively fine all day. I the evening I move it over in the driveway, no problem. 20 min later, no start, no turn over, I can hear a faint click seems to be coming from the starter relay in eng bay fuse box, shift indicator line absent, windows wouldn't work, interior lights didn't work.
I swapped starter relay with known good relay, no change. All eng fuse panel fuses ok except cig 20a so I replaced it with no change. No access to rear seat fuse panel due to damaged seat release cables.
This morning I saw MAY06LT vid and removed relay, jumpered the 86 and 87 (?) terminals and it starts right up. Replace original delay and starts again and again.
This afternoon starts right up and while driving T, fuel, oil, V gauges quit working and warning light check gauges lit up, no windows no int lights, kept driving. 20 min later all back to normal except security light on dash lit solid. Returned home, parked and restarted fine.
A lot to ask, but wth is going on? I'm desperate, I actually have a buyer for it (selling this to fund my 06 build). But can't do the deal knowing something is wrong. Any and all help appreciated. Bill
