Hello from queens new York and help!
Gerbil21
839
Mark@PCMofNC
25
Welcome to the site! Hope you get your MPG issues figured out
Gerbil21
839
Thanks, hey maybe I can get a free tune? It would be a great testament to your tuning service[emoji1]
Also thank to everyone else that has welcomed me!
Gerbil21
839
smt 59 said:
Welcome to the Nation-----Richmond Hill eh!
Try the PCM tune, worked for mine.
Thanks! You from new York?
Gerbil21
839
smt 59 said:
Just north of Toronto Ontario Canada
Oooh lol I kinda thought you might of been hinting at that but i didn't see your location [emoji1]
Reactions: smt 59
Gerbil21
839
Welcome to the Nation :thumbsup:
Thanks!
I love you johnny, but your not getting my bud light
Lol forget about the beer ill take the mpg
Gerbil21
839
CaptainKD said:
:tiphat: :tiphat: :tiphat: :tiphat: :tiphat:
HELLLLLLLLO AND WELCOME!!!!!!!
[emoji33] [emoji33] [emoji33] thank you, thank you [emoji1] [emoji1] [emoji1]
Mark20
1,630
Welcome aboard. I grew up in Queens. Born in Bethpage.
Envoys and TBs are heavy vehicles with big engines. Stop and go LI traffic does not yields the best mileage. I have to head up there regularly for work and rent a car as often add I can.
Gerbil21
839
Thanks for the welcoming! [emoji1] I understand what your saying but I should be getting better than this. My brother's jeep with 138k and previous owner neglect gets 12mpg, also a 99 blazer I had got bad mpg as well (15 mpg) all highway with 74k. But when it comes to weight my last car a 05 crown Vic police interceptor with 94k which weights the same and was always city driven and driven hard all the time lasted longer fueling than me feathering the envoy getting 8.7
Gerbil21
839
seanpooh
461
Welcome, born and raised in Richmond Hill (131st street). Maybe you're getting 9 mpg because of the city driving over there :rotfl:
Gerbil21
839
Thanks, and idk because my brothers jeep gets 12mpg
Paul Bell
460
Hey Gerbil, I'm not too far from you in Bellerose Manor (Queens Village).
You haven't mentioned the condition of your truck. Have you performed a tuneup? Spark plugs, filters, etc. Is the check engine light on? Any codes? BEFORE doing a tune up on my 5.3, I hit 11.4 MPG.
Gerbil21
839
Sorry about that here is the list of everything so far
Front & rear diff fluid
T case fluid
Trans. Fluid flush, filter and both shift solenoids
Engine oil (with 10w-30 by accident lol)
Power steering pump & fluid
Air filter
Spark plugs (acdelco 41-103) & coil boots
Coolant and t stat
Upstream O2 sensor
All fluids were top brand synthetics
Also did water decarbonization with 17oz bottles 3 times
kjkim93
696
I now have 100k and live in Queens. The best mpg I get is 12-13. The worst I've had was 8 and that was only during the winter.
Paul Bell
460
Well you certainly did a good bunch of work. Check engine light on? any codes?
Gerbil21
839
I only got two codes for low coolant temp (for the 160* t stat) and p0014 for the cam actuator solenoid I cleaned it and the code went away
then when I did the water cleaning I got random cylinder misfire and idle speed to high but I had the vacuum hose off and then yesterday I got p0014 again so I might have to replace it
Paul Bell
460
While the PCM will go to closed loop above 104 degrees and the O2 sensors are up and running, it may still be running rich until it hits it target of 192 degrees. Altough I doubt it's just the lower coolant temps, it's not helping your milage by causing a richer fuel curve.
Gerbil21
839
Oh my bad i forgot to say it had a 160* when I bought it but i changed it to the correct 195 when I changed coolant
Paul Bell
460
Well I'm running out of ideas. It could be driving habits, a dragging brake....
Gerbil21
839
Nope and nope but I will be using gm upper engine cleaner soon and some bg44K soon. And I will be cleaning the cpas
chriswilson5585
